measuring tools
topher5150
Grand Rapids, Michigan
I'm going to be getting some measuring tools for my job, and can't remember for the life of me what these things are called. They are for measuring ID you put the tool in the hole and twist the handle and two cylinders pop out then you twist the handle again to lock it pull the tool out and use calipers or a mic to measure it. Anyone remember what they are called
that tool is not accurate for most of what I do
you need a dial bore indicator much more accurate
from any of these
Starret, Sunnen, Mercer, fowler, Mitutoyo, Etalen,Mhar
I have never herd of it called a T-gauge is that old person talk
from any of these
i dont need a dial bore indicator these are cast pices so close enough is good LOL
I found a set of SPI 5 piece "T-gauge" set and a digital calipers from MSC, company is paying for it so it's all good
