04_Sport_LS
Merry Christmas to everyone. That's all I'm sayin... other than thanks BigRig for an early present about a month ago.
Quote BigRig:
" When do we do the "Airing of Grievances" ? "
Really??? You know how that went last year... and you still have to ask???
Please don't keep tempting me. Shouldn't be about the airing of grievances... but instead about forgivness.
I can forgive the LS. However... if I ever meet an engineer/designer for the cooling system on the LS,,, he's gonna get beotch slapped. Really??? Another 1-2 grand on the sticker price wouldn't have covered most of the cooling system components being made out of aluminum???
There BR... I "grieved",,, are you happy now?![]()
^ how bout them full spares in the trunk! LOL Damn Sub and rear deck speakers had to go cuz it weighted too much. also LOL
As far as the additional weight of aluminum over plastic on the cooling system parts... I doubt the difference would be more than 25lbs. Much worth it considering the headaches we go through!!!
You're fine... stay on your soapbox. I have no problem with it. Been there a few times on this forum. But... you will still have a hard time convincing me,,, that Ford cut corners on the LS to save weight... instead of $$$. The LS was never cheap,,, and even though at the time there was a joint venture between Ford and Jaguar... they were still in competition with each other. In my mind,,, Ford cut costs in an attempt to undercut Jag sales on the same DEW98 platform. Of course,,, we all know how that worked out. Jag took Ford's money,,, and is still using the DEW98 platform to this day. Ford walked away... because Jag bled them dry.
So there is another grievance. You happy again BR???![]()
... The window regulators are a prime example. BMW have been using the design for years and years without any problems. ...
I partially disagree with this. My 2002 325i has now been through all four window regulators, one of those twice. I can't blame BMW for one of the replacements failing, as I didn't use BMW branded parts, but the original four are on them. A check of the BMW E46 forum indicates that window regulator failure is about as common for them as for the LS. In my case, I've actually had better luck with the LS regulators.
I would hope that BMW has since improved on the design or on the plastics used, just as I hope that is true for Ford/Lincoln. I had to replace all the regulators on my 04 Grand Marquis, more than once. From that, it does seem that Ford had already improved a good bit by the time they got to the LS.
