Sifrino3
I have a 2002 Lincoln LS 3.9L. It does have Magnaflow exhaust and intake. I have never had a problem until the last few weeks. It started with a small mis every once in awhile at low speed acceleration. Then it was at any speed, low throttle.
Now I changed the plugs, someone put Fine-wire plats in before I owned it. I replaced with OEM plugs. I also om tested the coils. All eight coils we re very close to each other. No oil in or around the coils. Three plugs were different from the eight. (look)
New plugs seemed to fix the problem. I went from Arizona to Minnesota and didnt have one problem. On the way back, from Minnesota It started missing all the time w/ loss of power. (2 hrs before we got home.) No Check Engine Light, checked with code reader anyways. No Codes! If you put the gas pedal all the way down, It will accelerate like normal. If you ease the throttle it will miss. WTF! No Codes!
