module location
br94mk8
Portsmouth,RI
I think I need a module i get the check suspension message as soon as I turn the key Iv replaced the the compresser and the module and Im still grounded someone please help!!!!!I want my baby back.And were is the module.
You gotta take the passenger side kick panel out along with the underdash thing. Then you peel the carpet back a little and its pretty easy to spot. You'll see a black and grey connector going into it.
If you've already replaced the compressor and the relay, have you checked fuse number 20 in the power distribution box under the hood?
Maybe your bad relay or compressor blew the fuse?
I had to replace the module on my old '95. New compressor/dryer and the module and it was back to working like a champ.
If you can give us a lil more info than what you gave us, we might be able to help you out a bit. It is most likely not the module. I have yet to see one go bad, not saying that it has not happened, but I can not remember ever really hearing about it. I did not see that you replaced the compressor. It could be that the compressor is no good, but without more info it is kinda difficult to figure out.
Like ray said, more info would be nice.
*IF* it turns out the unit is bad, I have one out of my 95 that you can have. Pay shipping is all.
Mike
