moonroof adjustments
Ron
Ayr
When driving at higher speeds the wind starts whisling at the moonroof because when closed, the back edge of the moonroof is slightly lower than the roof itself. Is the hight of the moonroof adjustable?
Moonroof Troubles
You could try the drive motor synchronization thing. Please see my moonroof jammed post. If you need the instructions that were emailed to me, just let me know.:D
Thanks for the info.
If you have any instrcutions available then yes I would appreciate it if you could forward those to me.
I noticed that the rear side of the moonroof was lower than the roof when closed but I thought it would be ok.
I quickly compared it to another STS that was on the lot and it looked kinda similar.
However I think it should be level with the main roof. First of all it looks like soemthing is not right and secondly at higher speeds it starts to whistle which is annoying when driving longer distances.
Thanks,
Ron
