Moonroof Sticks
ZacUnknown69
Minnesota
As I usually do, I search before I post. But I couldn't find anything this oddly specific. Besides my moonroof and AC, EVERYTHING works on my car. So I must get my moonroof fixed - whenever I try to open it on up; it's clicks and makes this awful ratcheting noise. It'll open if I press the button and push on the glass. But it can't open under it's own power. It does this upon opening, and once it's closed completely. Does it use a regular window motor like what's in the doors? Or is it different? Regardless, whatever you believe the problem may be - leave a comment and I'll give it a shot. Thank you!
the gear drive in the back runs a toothed cable.
the gear is skipping on the cable.
i replaced the entire sunroof to fix, easiest way imo.
