well i am truly thinking fuel pump but maybe my cats are getting clogged, low end is not up to snuff and i got a chip, but i also got a cone type filter with little hot air under hood protection, i have hesitation on acceleration esp when getting on it ,i am going to route the filter into the factory hole with pvc pipe and mount the filter on top of where the compressor used to be(I have a coil over set up) anyway that should get a cold air type thing going, any more ideas on off the line and hesitation, fuel pump is in the works next and and new diff bushings and addco swaybar for rear, fact one is broke.and fuel regulator,anyway want that off the line power back again help me out gurus of the mod!
