MSD wires, is this the right part #?
I got those from Summit a month or two ago. Accidentally ordered the SOHC versions the first time, because Summit had those listed as the ones I needed. I got a free hat though.:woowoo2:
how u like em?
those were my very first upgrade i did to the mark along with fresh autolites 764's, when i bought it last year.
Plug wires
OK i just ordered the MSD Superconductor wires from summit....
i was told i need to route the wires on this engine a certain way.
i was told this by a friend with a 97 cobra. he lives in houston normally but is off at college so i cant look at how his are ran.
anyone have a diagram for me?
i sure hope this fixes the miss or whatever i have going on.
Bah! those suck balls! You know how people say you cant use platinum plugs on these motors? Balls! Ive used plats for over 5k miles and they work fine!
:confused:
plats are OEM.
as for routing..there is a proper way due to the firing order.
Get the dollar a piece Autolite 764s and make sure you match the right cylinders up to the right wire because it's like maze the way the wires run. If your wires are right now then just replace them one at a time to make sure you hook them up right.
