Here is the deal on the SRS light.
It flashes two codes - blink, blink, blink, pause, blink, blink = 32
These are called LFC codes and tell you what is wrong (not always where).
Here is the list - >
http://www.lincolnvscadillac.com/showpost.php?p=184120&postcount=2
The two most common issues are codes 32 and 36:
B1932 32 8 Driver Air Bag Circuit Resistance High Go To Pinpoint Test H .
B1993 36 22 Driver Side Air Bag Circuit Shorted to Ground Go To Pinpoint Test R .
B1992 36 22 Driver Side Air Bag Circuit Shorted to Battery or Ignition Go To Pinpoint Test T .
B1994 36 22 Driver Side Air Bag Circuit High Resistance Go To Pinpoint Test V .
B1995 36 22 Driver Side Air Bag Circuit Resistance Low Go To Pinpoint Test X .
The two most common issues are:
- the clockspring in the steernig colunm wore through and is either shorting or open - which provides the connection to the airbag in the steering wheel
- the connector under the driver's seat has broken - which provide a connection to the seat's weight sensor (partof the airbag system).
thread on the clockspring - >
http://www.lincolnvscadillac.com/showthread.php?t=6316
thread on the under seat connector - >
http://www.lincolnvscadillac.com/showthread.php?t=7068
