jgrimes22
hey guys. need some help. just traded my eldorado for a 1989 town car. however, it isn't well. it runs terrible for about ten minutes when the engine is cold. here is all the stuff i replaced or checked and found operational:
distributor (new), TFI module (new) IAT and coolant temp sensor (new), spark plugs (new), wires (good), cap/rotor (good), IAC valve (good, does the same thing off-idle), EGR valve, fuel filter (new), fuel pressure regulator (new, brought the fuel pressure from 15 to 35psi at idle), TPS (new), PCV valve (good), Vaccum lines (no leaks), reset minimum idle, reset base timing.
What the crap is wrong with my car? when i disconnect the SPOUT connector, it runs great at base timing. when i reinstall the spout connector, it idles erratically. the timing goes from base to about 40 degrees BTDC until the motor almost stalls, then it comes back and does it again every couple seconds. it won't even idle by itself anymore, i have to keep my foot on the gas until it figures out whats up. Am i looking at a computer? it's not throwing codes for the keep alive memory. thanks.
