Frogman said:If your Eclipse has a VSS tap then I'd say the eclipse. If the unit relies soley on GPS time hacks, then I'd say the Speedo. If you've just installed the headunit and it does have a VSS tap, give it several hundred miles to learn.
ltnate3 said:Yeah the Eclipse has a VSS tap. I was thinking that had to be the most accurate. Thanks!
beaups said:right and vss can be slightly off due to tire pressure, etc. sat should be very accurate but delayed.
Frogman said:Because OEM gauges aren't known for their uber l33t accuracy.
beaups said:looking at your photo gallery you have custom wheels? 20's? if so that would explain the speedo errors
Frogman said:No sir, they do use the VSS to calculate speed along with/or in lack of the GPS signal.
In tunnels and the like where I don't have GPS signal, the speedometer function on my D1 still shows speed. I can slow down, speed up, etc, and the D1's speedo screen updates in real time.
