need help installing upper control arm
guillotm
Clarksville
When installing the upper control arm, when do you tighten the bolts to torque specs. Is it when the tire is on and the car is all the way down to the ground? What is the easiest way to do this with jack stands and a jack? What is really meant by suspension should be at curb height. Thanks for your posts.
