TRUtoGIRLS
K so here is my problem.:shifty:
I changed all my spark plugs about 9 months ago.
And Today 9 months later.... My check engine light came on. Obvisouly because of a missfire. I got it tested and it was cylinger 3.
I then changed the spark plug in cylinder 3. and put here back together. Then The next day I had a missfire in cylinder 5. So I then took her back apart again and replaced all the spark plugs cause they are all under warrenty. The spark plugs did have carbon on the plugs, I believe cause I did uses cheap gas during that month when gas was $3 a gallon. I know it was stupid though. But they all got replaced Today
I then started the car with all the new plugs and the dang thing is still ideling rough and engine shakes. I did reset the Computer and the check engine light has not came back YET.
I also did replace one of the ignition coils in cylinder 5 as it was enlarged due to the heat and oil in the chamber at the time. I did tighten the head bolts down and there has not been any more oil in that chamber.
I have no clue what to do next.
I did order 4 more ignition coils at $38 a piece. Going to replace all the ones that look bad.
Info about my car is below.
2000 Lincoln LS
3.9L V8
91000 miles mostly Highway.
Someone please help!!!!!!!
2000 Lincoln LS
3.9L V8
