Robert Crain
2003 V8, 166,000 Every component of the cooling system has been replaced in the last 2-3k miles except the electric fans. First of all, thank you Joegr for your input on the chat line. The car has been running normal as it should. Last week. I was driving on the Interstate for a long period of time with no issues. At some point during this drive, I noticed the temp gauge jumped up to 3/4 hot then settled back down to 1/2 (normal). When I got off the Interstate onto a two lane road, the temp gauge pegged hot and the dash lit up like a Christmas tree. The coolant was boiling in the D-gas bottle. Every part of the cooling system is new-the radiator, DCCV, aux water pump, main water pump, thermostat, hoses, etc. Even that darn D-gas bottle is new. The system has not been leaking and there is no evidence now that something is leaking. My mechanic has flushed the system and says it might be a faulty heater control valve, DCCV or clogged heater core. I think his diagnosis is pure rubbish and he's only making guesses. I'm thinking I should start by removing the thermostat and assess that there is good coolant flow throughout the system. If there is, then maybe the thermostat is faulty?? Could use your input on a diagnosis strategy. The mechanic says he could get the electric fans to work as I initially thought that might be the problem. Just wanted to add that replacing that plastic elbow pipe located underneath the air intake was one of the worst automotive experiences of my life. So what do you think is going on here? Help! Thank you.
