Need help w/ 1998 STS interior water leaks
trondw
Norway
Hello,
I hope someone can help me with some problems we are experiencing.
8 years ago we special ordered 2 Cadillac STS 1998, so they are produced after each other. We live in Norway. Whenever there is a problem, they occur for both cars, typically within weeks. The only Norwegian authorized Cadillac car dealer can not fix the following 2 leak problems:
1. Both cars leak on the driver side and passenger side. The water comes in through the seals ABOVE our heads, by the roof. Everything has molded along both sides of the windshield in one car, and the 3" wide plastic pieces cosequently fell off. We guess the problem is related to change of windshields by the Cadillac local dealer.
2. Both cars leaks water into the trunk. Water assembles by the extra tire whenever it rains.
Has anybody experienced similar problems? Thank you!
Trond Wurschmidt
(FYI. Earlier problems. Both cars: Trunk started to open by themselves. Engine oil leaks. Sun roofs started to open by themselves. Gas lids started to open by themselves. Fuel gauges always on full or empty (repaired 4 times, each car). Rear brake tail lights out (repaired 3 times, each car). Lights went out on A/C displays. One car: shock absorbers gone at 50 000 miles. Broken front engine mount. Other car currently in for fixing steering servo. Plus more problems I do not remember off the top of my head. I think we were a little unlucky with these cars.)
