need help! window switches and door locks won't work
cwdeman
Byron
the only switch that works is the drivers door controls, none of the others work. also, only the drivers door lock works
Are you just telling us this, or were you wanting some help with getting them to work?
If you want help, you need to give us some more information.
What year is your LS? There are some differences in the way the windows are wired between the two different generations of the LS.
Do all of the windows work from the driver's door, but not from their local switches? Are you certain that this includes the front passenger door? Are you certain that you have the window lock switch off? If you put the key in the driver's door and turn it to unlock and hold it there for a few seconds, do all the windows open? If you turn it to lock and hold it there, do the windows all close?
Do you mean that only the driver's door locks and unlocks when using the lock switch inside? Or, do you mean that the lock switch on the passenger door doesn't work. Do the locks work when you use the remote? Have you pressed unlock twice on the remote within a second or so?
Did everything that isn't working stop working all at once, or have different things stopped working over time?
it is a 2001 lsv8, all of the windows work from the driver's door none of the other switches work, i have checked the window lock. the driver's door locks and unlocks from the button, but none of the others are affected. everything stopped working yesterday
It sounds like you may have a problem with your REM (Rear Electronics Module), or the wiring to it.
