need help
black-ls
vancouver
hey i got a 2001 Lincoln ls V8. i just put a new fan and radiator. My car makes a weird nosie when ever i turn my a/c on and it over heats. Aslo when i step on da gas pedel around 1200 or 1500 rpms it makes a squeeling nosie. can anyone let me know whats up with that.
The squealing when you step on the gas could be the drive belt slipping. Did you replace the hydraulic pump for the fan also? Have you checked to be sure the fan turns on when you turn on the A/C?
ya i put new fan a pump. ill go check if fan turns on is it to turn rite away when i turn a/c on or do i have to wait a bit b4 fan kicks on?
black-ls
figured it out they put in a bad fan and pump so that solved all my problems yeah!
