You have to pop off the plastic cover. Pull the sides out from the back, against window, and pull towards the front of the car. The bulb should be right behind that. To put the plastic cover back on, push in the sharp edged corners in the back, against window, and slide back in place. You will see the track on the plastic cover that needs to line up with the one on the housing.
