DieselDan
Hey guys, I've got an A/C issue and maybe need a little help diagnosing the problem...
Here is my problem, last week the A/C quit. I assumed it was just low on refrigerant and gave it a quick check. The pressures are good so, that isn't my problem.
Here is a copy of the diagram -
Checking the power at C118 pink wire. This is the connector that connects the engine harness to the body harness. Below is a video showing what kind of read I am getting from it.
http://youtu.be/tFkaoZU8qYg
The voltage is very irratic. Sometimes the test light is extremely dim, and other times the light gets very bright like in the video, and the clutch intermittently engages. I need to check my voltage at connector C121, but I am leaning towards this kind of voltage reading being a bad VCRM? Looks like the VCRM is a pita to pull out to back probe, but I'll check it out this afternoon. My question is if anyone has had a similar experience with this.
The problem is also dependent on the car's temperature. Usually when I first start the car, the clutch won't even try to engage. As the car warms up, the clutch is more and more likely to engage. There is no change if I jump the Low Side cycle switch, so this is not a refrigerant issue. Any help is appreciated, I haven't really screwed with the VCRM before.
