Need some warmth... Help???
dj_jace
Winchester
Well I'm almost 100% positive the DCCV valve is bad in my 02 LS... During the summer I get cold air out both sides.. but winter passenger side gets no heat at all and drivers side is barely warm.. and only really gets warm if I have my foot in the gas... idle doesn't stay that warm... I hadn't rushed to get a DCCV b/c I was ok with wearing my jacket and then using the heated seats... well just my luck now the drivers side heated seat quit working... passenger side still works and the drivers side button works... it lights up as normal and goes off in the 10 mins like normal but no heat to the seat... I found a pdf online that was talking about checking voltage and resistance from the pins but when I looked under the seat there are like 3 or 4 plugs so not sure what is what... Any advice on what to check on the drivers side heated seat?
Jason
V8 or V6? If V8, then your aux pump has probably failed. Otherwise, it could be the DCCV (but it is rare for them to stick in the no heat position), it could be a clog (probably in the upper radiator hose tee screen, or it could be air in the cooling system because of hairline cracks in some of the plastic cooling system parts.
The wire heater elements behind the seat covers fail. The only solution is to replace them.
Its a v8... ill check out the radiator hose... need to figure this out... been super cold lately... today was a little warmer but going to get cold again... ill look into getting the heater elements replaced...
While experiencing something similar to this, I was convinced that my heater cores were fouled internally. I added flush last Tuesday and ran it until Saturday, noticing a heat increase from 85 degree air with 24 ambient outdoors, to 110 in this time span with the flush still circulating. I added one more bottle Sunday (prestone product) and wow, I had 130 degree heat! I flushed it and rinsed the system twice with plain water before refilling with 50/50 premixed prestone. To my astonishment, my ride to work in 20 degree air showed me only 60 degree air. I bled air, or tried, to, 3 times on Monday. The only time water would flow out of the bleed port for the heater was when the engine was decellerating. It never flowed as it should when all of the air is purged. The drive home Monday was terrible, 38 degree air out of my heater while ambient was up to 34! Back to the garage, I tried more purging, same results. It just got worse and worse. I ended up hoping that I was right, that the DCCV was bad. I ordered one on Amazon Prime, bumped up delivery to one day for $5 more, and received the valve Wednesday. Long story short, it fixed the problem, and the heat now responds in real time to temperature changes. My best output in 27 degree air today was 142. Setting the temp down immediately sees the output drop, increasing it gets immediate results.
The job sucked! I have a lift and must have cycled the car up and down over 30 times while trying to get the advantage I needed to remove the spring hose clamps. (I decided to take the hoses off the valve instead of the service manual's destructive recommended quick disconnect method) I had a bear of a time getting the hot inlet hose clamp released, could not get a position for the special cable operated tool to release it. I ended up using a reciprocating saw to cut off that line from the valve, since it has a right angle and lots of exposed plastic. Each clamp was a challenge. I am sure that I could do the job faster now, but I put 3-4 hours in to get the old one out. No way was I going to use those clamps it came with again, but to be honest, spiral worm gear hose clamps were not that easy to service on a few of the connections, either. This is Gen 1 V6. I spent around an hour and a half getting everything back together, it took a half hour to burp the system after starting it.
BTW the coolant that I flushed out was very clean looking, so the flush compound is pretty mild. That must be why they say you can either use it for a 10 minute flush or a 3-day flush.
Amazon's price was great, around $147 for the valve, from Motorcraft. The order was placed around midnight EST, and left New Jersey at 4 AM. It was in Massachusetts by 8:30 that same morning, and sat there for 12 hours until moving to Nashua NH for distribution to the delivery truck. You can't beat that service and price! It's a bit less money on rockauto, but that's always a 3 day process for shipping calculated at 10% of the part cost.
Note: I cannot imagine doing this job without a lift! I know everything is possible, but seriously, there is so much work topside and below back and forth, you really have to be determined to get it done on jack stands.
Props to JoeGr, he was calling out the DCCV from the get go. :-)
I've done it on a 2000 V6 and a 2006 without the tires ever leaving the garage floor. The 2006 was much, much easier than the 2000; fewer connections and all. I didn't have the clamp-release tool and had to use Channel-Locks to release the clamps. It was by no means easy and, IIRC, took more than a couple of hours!!
You're the man! That had to have sucked. Did you use the quick release on the hoses where they meet the aluminum tubes?
I recall using some different words for that valve when I had the pleasure of swapping mine out. Fn thing!
Mind ya, you gotta move some things out of the way and it's on a bracket which needs to be loosened.
Had my Aux flow valve off anyhow for replacement but was still to date the worse repair for me on this LS.
Scratches on the inside of my right arm from the damn fan shroud. (only cuz I was doing the entire cooling system re&re)
and BTW with the clasps, you really should pinch them, move them up the line then work on getting the hoses off the nipples.
Yeah I think im just going to deal with it for now and change the dccv once it gets warmer here. Dont want to be outside in the cold trying to swap this out... lol... my ac compressor has been making noise for aome time now and it needs to be swapped out too I think... even when the ac swith is off the clutch never full disengages... also I think this is the reason my car bogs down every now and then at stop lights... id have to take a short video clip of what the compressor is doing to fully explain...
Correction: Aux flow valve, I mean to type Aux coolant flow "pump"
Jace, my little '97 Maxima winter beater, the compressor is noisy on it also, started since the colder weather, I try not to use the defrost too much and just turn up the music. Solves that problem for now. Not messing with it unless I have to.
