Phatt_daddy
02 V6 w 166k. Recently replaced the valve cover gaskets, new Motorcraft Platinum plugs and new coils. Problem is that upon start up I;m sitting at 500 rpm for like 5 min and then progressively increases to 1k. Driving is decent with minimal power loss ( hence the rebuild- worn rings), but at a stop I have to kick the car into neutral and pat the gas to keep it at 1k idle until I move or the car dies. Several mechanics I've talked to have said "its a ford, replace the IAC" but none of them have worked on this particular line of car. I know this cant be good for the engine or the tranny either one and I want to be able to drive it somewhat trouble free until I can rebuild the engine in the spring as this is currently my only vehicle.
Thanks,
Nate
Thanks,
Nate
