new here, have some crazy electric issues with my mark viii
leifsmom
salina
well....was having some issues before, replaced the alternator about a month ago, most seemed ok after that. but now theyre back and then some. first, the turn signals on the passenger side will not work, or the brake light, which is odd because all the bulbs work. i can fake a front turn signal if i manually switch the turn signal lever up and down. the drivers side lights are all ok. the odometer has suddenly stopped working, today, another symptom reappeared. the ac keeps kicking itself on and off, im not positive but it seems to shut off when i use the brake and come back on when i step on the gas. now i just pulled into my drive and i got the check air ride system warning! what is my problem here? is there some other part that makes all this stuff act screwy or is all the wiring just shot? any suggestions? please help!!! btw its a 94
as far as your blinkers go, its probably time to get a newer Multi function switch for your steering coulmn. welcome to the group!
had the alt checked today, its good. of course! that would have been too easy!
