New owner of 02 ls v8, throttle sticking need help
02lsveight
Inland Empire
I just bought my LS 2 weeks ago and love it. I romped on it a bit getting on the freeway today and the throttle stuck. The rpm was stayimg at 3000 and I had to ride the brake to keep it from accelerating. I got off at the next exit and it unstuck and I was able to resume normal driving. Any help would be appreciated in tracking down this problem, I don't want to be afraid to step on the pedal. Thanks in advance.:confused:set
Check for sticky throttle linkage. Also the pedal mounting.
I got it to do it a couple times with the car off and it feels like the throttle cable is binding up. Off the next two days so hopefully I can track it down. Maybe some graphite lube in the cable? Or is that a no no on these cars?
Chances are the throttle body is gummy. Start there. I cleaned mine out with clean towels, rather than using the cleaner, but it wasn't too badly gummed up. Solved my sticking problem.
Search this site using google (site:lincolnvscadillac.com lincoln ls throttle body), and you'll find posts with pics of it's location and how you get to it.
use "site:lincolnvscadillac.com" to search everything else you have a question on
This happened to me also. It turned out to be the plastic cover under the dash. There is a very narrow gap were the petal arm can make contact with the cover. I must have kicked it or something. Moved it back and was good to go. Hopefully your fix will be as simple as mine was.
