I just finished swapping my interior and now the rear dome light and door ajar light in the cluster will not turn on when a door is opened, but the two dome lights up front will. I'm assuming the car knows the door is opened (front dome lights turn on, chimes when driver door is opened) but it does not register on the cluster. Is it possible I blew the bulb on the cluster as I was swapping the interiors? Does the v8 have a different wiring harness for the headliner?
Just for reference, I used the harness that was on the "new" head liner which also included another harness for the auto rear view mirror but I didn't swap that in. If I press the button on the rear dome light, it will turn on but it will not turn on when a door is opened.
Interior was swapped from an 00' v8 into my 00' v6.
