Ok, I've done some searching and looked through the stickies at the top of the page and Iam still at a loss. I'm hoping to not have to tow it to a dealer, because the closest one is ten miles away.
I adopted a 2001 LS v6. It was originally parked about eight months ago, because it was missing on one of the cylinders. The battery had been taken out to use in another car. I was figuring on cop and plug replacement. Installed a brand new battery and tried to turn it over the fuel pump doesn't even prime. I've checked the fuses and the shutoff switch. All the fuses are good, and the reset switch didn't help. Had it towed to a local mechanic that was recommended to me. He double checked the fuses and pulled the fuel pump and tested it outside of the car and it seems to work fine. It's just not getting any power from the car. He tried to get it to fire using a little starter fluid, and it doesn't seem to be getting any spark. Any ideas? If I can save myself the cost of a tow to the dealer I would be super happy. Any insight you might have would be greatly appreciated.
