MRB73
I just got a 92 Mark and today when I tried to get the heat to work all that came out was cold air even though the climate control was on 90.I checked the coolant level and it was full.After about 10min. the temp. gauge went from cold to full hot so I shut it down because I didn't want to risk it overheating.What should I do?
		 anyway i am still having the same heat problem with my car. heat is all the way up but nothin but cold air coming out. i did locate the blend door and yes it is working (opening and closing) but still no heat. funny thing is when i have the blower on the lowest setting warm air does trickle out and eventually warms the car but when the blower speed is increased no heat can be felt. i did not check to see if the heater core is connected but i assume it would be or i would not feel the heat that comes out when on low setting.
  anyway i am still having the same heat problem with my car. heat is all the way up but nothin but cold air coming out. i did locate the blend door and yes it is working (opening and closing) but still no heat. funny thing is when i have the blower on the lowest setting warm air does trickle out and eventually warms the car but when the blower speed is increased no heat can be felt. i did not check to see if the heater core is connected but i assume it would be or i would not feel the heat that comes out when on low setting. any ideas?
 any ideas?
