No Radio
Markviiiedrea
Speed Bump
Bloomington, MN
Got into my mark today and my CD player is inop along with my message center (wont even display time). Also the gas gauge is peged beyond full. Checked the fuses and there all good. Any one seen anything simular in there cars?
pulling fuse 16 does exactly what you describe. make sure you check the fuses thoroughly. i've seen bad ones that looked great until i checked them with an ohmmeter.
otherwise, check for power at the fuse box or something along those lines..
Still having trouble with this, I poked around some more with it this weekend and still found nothing. Fuses are 100% good and no other issues other then...
-Fuel gauged pegged past full
-No radio
-No message center
-Occasionally my HVAC unit displays C or F whenever it feels like it.
All this seems to be a loose wire somewhere or maybe a short, I looked in my EVTM book and haven’t gotten very far. Has anyone had similar symptoms? The only thing I have done recently is re-installed my subs/amp (there were removed just for storage purposes)
I’m getting sick of hearing all the rattling in my car and need my luxury back!
just a fyi, i fixed the issue that sounds just like yours. i would double check that the white with purple wire has power if not, the that is the problem. Trace it back and check why. Good luck
My car did that when I had a partial alternator burn out.
