There's no real easy way to go about doing it. It's a PITA no matter how you go about it. The first thing you shoud do is make sure you have a clutch adapter for the proportioning valve near the drivers side rear wheel. Take it to napa or someplace and you should be able to find one. I found it easier to bend the lines as I went rather than prebending them... Other than that just make sure you have a flaring tool, and some bandaids because you may need them after doing the crossover line.
