Not So Good Vibrations.
JoeyLincolnMK8
Queens, NY
whats going on guys, i know the common problem about the issue on vibrations at high speeds. I get them pretty bad past 80mph, i have a 93 so you can rule out for the most part the driveshaft being a 2-piece. any ideas what else i should look into for a fix for this? i have read maybe warping of the rotors, or even tranny fuild to low can cause this. if i answered my question on this with either one of the above guesses i made, please let me know. any help is defiantly appreicated. thanks!
here
My car stopped all vibration after new tires and good balancing, problem came back when tires were almost worn out.put new tires on again problem solved, just make sure to keep your tires balanced during their life, Tires have always made the difference,drive a car with worn out tires then with new ones and it's a night and day difference.Also replaced tie rod ends, got rid of that wandering feel in cornering.
thanks, everyone. but i think i have an idea of my problem. i believe that it is because of the fact that i have 3 uniroyal tires and 1 kuhmo (which is in the front). because of a flat i had a few months ago. im thinking that the thread on the kuhmo does not match up with the thread on the uniroyals. but actually down the road im going to replace my tie rods ends. I have changed both my air struts, upper control arms & ball joints. so that rules out the chance of those being bad. so JC1994, i totally agree what you are saying. thanks again guys!
