So this issue has started to get worse lately. Apparently it's bad enough now that I can get smoke puffing out the exhaust. Robot let me know about it a few weeks ago. I always figured it was a sticky injector but never had much in the way of smoke before.
Here's the symptoms:
1) 3/4 to full throttle
2) Start to hear a knock or rattle sound
3) Start to see some light smoke pop out the back (Robot said it looked grey, hard to look back while at full throttle)
4) Rattle can go on for 5 seconds sometimes, other times it happens for 1-2 seconds
4) Soon as the knock/detonation/rattle sound stops, smoke goes away
There is no correlation to whether the engine was just started cold or warm, of if it's been running for an hour. Usually happens under high acceleration depending on if the engine is chugging in a low gear or revving high (not the typical coil failure behavior).
I know I have a noisy injector in there somewhere because it quiets down with some top-end fuel treatment like Lucas. So I am thinking it's a few things
1) Injector getting stuck open or not firing right
2) Cam advance mechanism isn't doing it's thing right
3) Knock sensor is garbage
4) O2 sensors are garbage and the ECM doesn't really know what's going on
5) Bad coils/plugs somewhere (Using the accel coil conversion)
One interesting thing to note is that it always kind of did this even before I did the coil conversion. It has just gotten more reoccurring lately and lasts longer. The smoke thing is new and probably popped up in the last few months.
Any ideas?
Any ideas?
