I know you guys have talked about this before, but I get a little lost when the talk goes beyond spark plugs and ignition coils.  I have an 01 LS8 and am having a cylinder misfire issue.  The service engine light is on and it runs very rough and makes a knocking sound when idling although it seems to run fine when driving down the road.  I took it to AutoZone to have them read the code and it was reporting a cylinder 4 misfire and that the gas mixture was to lean (he said this was prob related) so I replaced ALL the spark plugs and the #4 ignition coil (passenger side rear).  I just started it up and it is no different.  I've seen in previous threads talk about leaking injectors causing misfires. Could this be my problem? and how hard is that to fix? Please don't make me take it to the mechanic!!!
