Obsolete Strut Rod needed or where to find
1BadMoJoe
Broken down Hours from the house
Obsolete Ford/Lincoln part, this is the mildly shaped S curved piece that connects to the lower control arm forward to the frame, which are affixed the common to find strut rod bushing kits; to frame, to arm
Problem; The rusted end nuts of the bushing and washers to the threaded strut rod will not let go; penetrating oil, Big impact, "lightly" heating the nut using torch has not worked...
1.) Easy fix is to torch/cut the nuts and threaded tips of the Strut Rod to replace the strut rods and both end bushing kits with the new Moog lower control arms going in.
a.) No replacement can be found for the strut rods...that were not cut yet.
b.) none on eb.ay, only hundreds of listings for the bushing kits, which I already have when ordered LCA.
