Odometer Question...
jjcool00
Elizabeth
So here's a weird scenario I encountered this weekend. I know bigger wheels throw the speedometer off but has anyone seen a case where it throws the odometer off as well? The reason I ask is because now that I'm moving I spend every weekend driving up north to apartment hunt. When I plugged the address into my GPS it said it was 243 miles. However, when I reached my destination my TRIP said I travelled 260? I took no alternate routes and reset it as soon as I started. Maybe my GPS is wrong? Or are the bigger wheels actually contributing to me driving adding phantom mileage to my car?
Yes, how could it possibly effect that speedometer without also effecting the odometer? They are both using the same speed pulse signal. There's no magic here.
I guess I didn't realize that would be one of the disadvantages to going with larger wheels. I never plan on selling my car unless I get an offer I couldn't refuse but if I had known id be devaluing it more than I already am I probably would've never gone with bigger wheels. Thanks for the response, Joe.
Shouldn't it work the other way around? A bigger wheel rotates slower than a smaller wheel so actually travels fewer miles. correct?
Use a tire/wheel calculator and try and stay within a percent or two of stock.
I have no idea mathematically how it SHOULD work, all I know is that somehow approx. 20 miles got added to the odometer.
I've noticed a discrepancy between mapquest, google maps and my NAV between destinations, using the same routes; though not THAT extreme. Weird........
Could the GPS have rerouted to a faster but longer route mid trip?
Yes, a larger wheel makes fewer rotations for a given distance, meaning fewer miles recorded by the speedo and odo. Your speed will be higher than what the gauge reports. You also lose a minor amount of torque
As far as I know it didn't do any rerouting. The trip was supposed to be 243 and when I got to my destination it was over 260. I have 19"s. I'm going to make the same trip this weekend so I'll check to see if it does it again.
Get on the intersate. Zero your trip odometer as you cross a mile marker, then see what it reads at the next mile marker. If you can, go ten miles to get a more precise reading.
If you have a smart phone, you could download apps that you can use to compare speed and distance traveled using gps. For my Android phone I have Car Dashboard, which shows speed, altitude, direction, local temperature and time; I don't think it has an odometer function. Another app for Android is GPS Odometer, this one will give you distance traveled and average speed.
