M
my95mark8
Guest
Today I replaced my oil filter adapter gasket. Now my oil light comes on.
It flickers at idle, and gets brighter when the rpms go up.
After I finished working on it, I drove it about 20 minutes, no problems, but later I drove it, and the light started coming on, so I brought it home and parked it.
I changed the oil and used the same oil that I have been using, and a FL-820s oil filter. It doesn't appear to be leaking, and the oil level is fine. There are no strange noises.
I don't see how changing that gasket would affect my oil pressure. I made sure it was the correct gasket, and it seems to have gone in correctly.
I have a few theories about what might be going on here.
1) Maybe I have f'd up the wire or connector to the oil pressure sensor. It did get soaked with coolant when I was working on the gasket, I didn't bother to clean it off. Maybe there's a bad connection?
2) Maybe I somehow f'd up the oil pressure switch..
3) Maybe a defective oil filter?
Anyone have any other ideas or suggestions?
Thanks.
Thanks.
