95lscowner
any one have this problem before on the readout when i do a system check it says oil temp signal error just wondering what that can be thanks
chris
chris
either a bad sensor down on the oil pan,or as was my problem the sensor wire was broke about 3 inches off the pan.95lscowner said:any one have this problem before on the readout when i do a system check it says oil temp signal error just wondering what that can be thanks
chris
Moes8 said:either a bad sensor down on the oil pan,or as was my problem the sensor wire was broke about 3 inches off the pan.
anything else it might be,i dont know.check those wires first
