I recently purchased a 93 Mark VIII that came with no keys. When I got the car I could open the trunk using the remote switch on the driver's door. The switch will no longer open the trunk. Any suggestions on how I can gain access to the trunk.
414Boy said:I recently purchased a 93 Mark VIII that came with no keys. When I got the car I could open the trunk using the remote switch on the driver's door. The switch will no longer open the trunk. Any suggestions on how I can gain access to the trunk.
JoeyGood said:check the fuse first but you ca bypass the switch manually just jump it
JoeyGood said:if the fuse is not the issue take the switch out and and jump the wires under it sort of like hotwireing the car but your only doing the switch
414Boy said:The fuse is fine. I took the switch out and jumped the wires with no luck.
So does anyone know how to open the trunk while on the inside of the trunk (I went in through the back seat)?
fastmarkviii said:how did u fit between the x brace behind the seat? lol
my95mark8 said:I wonder if the wires broke in the trunk...that happened to me. The harness by the driver's side trunk hinge.
Frogman said:some idiot problably locked himseld in the trunk, and now it's a Federal mandate to put the effing in-trunk release mechanisms in there.
JoeyGood said:NAHHH i think it was all the all the kidnapings murders and stuff.
from the movie ANALIZE THAT! "Look at how much room you get, enough to fit 2 bodies in there"![]()
