if your 6 feet tall you wont fit lol tons of torque steer, bad gas mileage, kinda ugly, cheap interior, for a teenage girl its a good car, for a man in his 30's 40's go with a ford five hundred.
False. I'm 6'3" and I had PLENTY of room. I had a ZX3 and it had a really tall roof so I fit perfectly, and I was able to fit my legs good too.
Interior is cheap only on the 4 door. For whatever reason they cheaped out on that version. The ZX3 interior was really nice.
Transmission wise the shift linkage is a major weak point. It broke 3 times on me by 45,000 miles. I bought the car brand new. I sold it back in 04 and just recently checked up on it via autocheck and supposedly the shifter linkage broke 3 more times.
Performance wise I had: Superchips chip, Steeda cai, fidanza adj cam gears (dyno tuned), focus sport orp, Ford racing underdrive pulley, 4.06 gears, centerforce dual friction clutch, Steeda short throw shifter, Steeda chrome-moly strut tower bar, Polyurethane transmission mount and 17" SVT rims.
The 4.06 gears although they made a difference, defeated the purpose of having a 4cyl because the RPM's were WAY to high on the thruway. That is a mod I wouldn't do again to that car if I had another one.
The shifter was a must because the stock one sucks at life, however make sure to see if anyone has an aftermarket update to the shifter linkage problem.
The strut bar and poly trans mount made a GIGANTIC difference in standing starts. It used to have massive wheel hop when I would dump on it. After adding those it had virtually zero hop, and would connect and go. It also was much stronger into the turns.
Honestly the car was very, very easy to mod, was quite dependable minus the linkage issue, and was the best handling car I've ever owned (it even out handled my 03 GT vert). I was able to take an on ramp at 90mph with out thinking twice. Speedwise they are much more fun once you start modding them, but are not fast stock.
The SVT is nice but has less available for it, and its more expensive to mode. The SVT however has a 6spd as opposed to a 5spd so changing the gears would be a possibility on it.
Honestly I would love to buy another someday as an auto-x car. It was a really fun car to own and I miss it sometimes. Just don't buy the 4 door Focus because for whatever reason those cars sucked at life...the majority didn't have the Zetec engine either...also the 03 ZX3 had the duratec engine that was hard to mod and easily blew so avoid that one. I'd stick with an 02 if possible.
btw, don't get a true CAI for that car. I had an AEM cold air intake that went under the car and the car was faster with the steeda. When I worked at Steeda I got to test the difference between the two. The short ram worked better because it had a more direct, shorter and straighter airflow.
Hope all this info helps. If you have any other questions feel free to ask me
