P0175 been thinking....
Ch1ll1ng
Sandy, UT
I'm throwing code P0175. I'm also having the hard start problem so I definitely think it's my fuel injectors or the fuel pressure regulator.
I dont have a fuel pressure gauge and I'm not sure if I would even feel comfortable testing my fuel pressure myself.
Anyways, I also idle a bit rough and have a slight hesitation when I acclerate from a stop. Is it possible my fuel pressure regulator is bad and is allowing the injectors to flood the cylinders which might cause it to idle rough? Or is it just probably the injectors that are leaking. If the cylinders are flooded, the fuel would leak down into the oil and I'd find some fuel in my oil right?
Oh, if it was the fuel pressure regulator wouldnt it throw codes for both banks?
I think I'm gonna have an experienced emissions tech look at it but I just wanted some advice so I dont get totally screwed.
Thanks,
I'm gonna clean up the MAF and I was thinking it could have been that for a sec cause I do have the KKM intake (new, I havent re-oiled it yet) on it, but I just havent heard anybody else have a problem with the KKM intakes being over oiled. But I am going to clean it up.
