Hey guys, so go figure, I had to go to Ohio last week for work and on my way down my car started what seemed to be a mis-fire here and there. This morning on my way in to work, I stopped and got the codes pulled.
They gave me the following 3
P0316 - Crank Sensor
P0420 - low bank 1
P2072 - PCM is indicating that the throttle mode has been activated - Explanation - ECM strategy has performed several open and closed cycles to remove possible ice build-up - Probable cause - moisture or oil in the induction system may indicate a PCV problem
I popped the hood and noticed that on the left side (drivers side) I can see some oil seepage which is new.
Car is a 05, with 66,xxx miles, V8.
I figure I'd start with coils and plugs and since I see oil, do the valve cover gasket, PCV valve and see where that gets me.
What do you guys think? Before I got started I figured I'd see if you guys agree or if I should start somewhere else?
Thanks for the help!
P0420 - low bank 1
