P1409 Code Help
cowels
Wixom
I have a 2000 ls 3.0l and i have p1409 cel on. I replace the egr vacuum solenoid and the dpfe solenoid and I had cleaned the egr valve and i still have it on. I am starting to wonder if i crossed the vaccum lines for the dpfe and if that would cause any codes to come up. also i am trying to replace pcv and i know its under the air intake manifold but when i had it off I did not see it.
I have the same problem! I already replaced the egr valve, did not help. I figure that it is the differential pressure transducer on the back of the intake. I am just trying to figure out which one to buy, since they run anywhere from $28 or so to over $60...
Pcv
On V6 the PCV tube from the throttle body goes back toward the firewall then to the right rear of the intake manifold, connects to a rubber adapter, $14 @ dealer, then goes under intake manifold fwd to PCV valve installed in small black plastic box opposite COP #5.
help!!!! fuel injector connectors
I took off my air intake both upper and lower gaskets and i found where my pvc goes and It was under the fuel injectors in a black box. only problem now is connecting the injector connector,. they are not locking back on the injectors. also the little lock clips seem to be lose. hope they are not damage. please need help, reply letting me know of any problems with this.
thank you
thank you
They are broken. It's not uncommon for the clips to break. You should be able to secure them with some Ty-wraps. You'll have to do something, otherwise they will vibrate out.
