Part number ,please..
Darrian Plasse
If any of you guy's have the part number for the hose at the bottom degas bottle...I recently replaced it and mangled the original hose doing the swap, the parts stores around herer didn't have one so IO used some universal buy by the foot hose...well its not cutting it...any help much appreciated..
So you bought the Dorman bottle? It won't last long. Just take a piece of the original hose with you to the auto parts store and buy a long enough piece of the correct diameter hose. It will be good enough to match the Dorman bottle.
The Motorcraft bottle that you should have bought, comes with that hose.
He that Hite whom sees the future!
Thanks for the advice,and you may be right aout it failing. However,in the event that it holds up I would be greatful for the part number in the mean time. I am sing a straight hose now and it has kinked up,blocking the flow from the heater cores making it impossible to bleed.
5W4Z-8A080-AA
AFAIK, this is only way to get that hose from Ford.
Thanx bud, I'm good though got one from local lincoln dealer installed and problems have resolve. Thankfully..
