Where is the best place to buy upper control arms. Keep in mind that I live in Hawaii and shipping sucks out here. I also need spark plug wires, and no offense geno, but I dont have 350 bucks to spend on em.
Marine said:Where is the best place to buy upper control arms. Keep in mind that I live in Hawaii and shipping sucks out here. I also need spark plug wires, and no offense geno, but I dont have 350 bucks to spend on em.
Marine said:DONE! called up Max and ordered them. Now I have to put them on....
1wykdmk8 said:Glad I could help.....it is a VERY easy installation process. If you need help you can give a holla and I am sure someone will be able to help ya out.....if not me. I have done this several times on the 93-96's I have owned..... :Beer
Markviiiedrea said:i bought mine when you told me to , and that was 2 months ago, im finally putiing them in tomarow, still not looking forwerd to it.
1wykdmk8 said:Dude....you have my number, give me a call. It is EXTREMELY easy to do this. It took me about 4 hours to do both sides the first time I did it, and about 2 hours (including eating lunch) to do both sides the second time. :Beer
motor mount "shuters run down my back" um live with it,Marine said:can you gimme the lowdown on doing it? I also have to replace the motormounts, and figured it might be easy to do it all at the same time. Should I do the struts too??
Markviiiedrea said:motor mount "shuters run down my back" um live with it,
well the tires , come off diconect master cylinder remove moduel unbolt top of strus and bottom un do bolt for control arms pull out replace, the other side is the same but you dont have to move a master cylinder3 hours tops + a case of beer 5 hours
1wykdmk8 said:Man.....you did more work that you needed. You do NOT have to unbolt the bottom of the struts. :Beer
