PCV Valve Info
JoshMcMadMac
Waynesboro, PA
[font=Verdana, Arial] I started doing some maintainence on the VIII today. I got the spark plugs swapped out, which was probably the easiest plug change I've ever done. I also replaced the air filter, which was probably the hardest air filter change I've ever done.
[/font] [font=Verdana, Arial]I did SeaFoam by letting it be drawn in through the PCV line off of the air intake, but it didn't have the affect that I've had with the VII and Camaro; it just drank it up and that was it. No bogging, no smoke, nothing. I guess that is a good sign.[/font]
[font=Verdana, Arial]Then I went to replace the PCV. I had purchased a replacement, but the PCV end is not large enough to fit snug in the line. More importantly, the "PCV" valve that is in there is by no means a PCV valve; there is no valve at all. There is a black piece that is the shape of a PCV valve, but it is a straight through piece with no valve inside it. It does not appear that anything has broken off, as this piece is black plastic and looks stock. Can anyone shead some light on this, and help me get the proper PCV valve to put in there?[/font]
I got mine from Max at 5 star Ford. Mine definitely has a valve in it (I can shake it and feel it move). I also did the Sea foam deal with the same results as you.
What is the " sea foam " thingy ?
It's just a solvent to clean your fuel injectors and such that you add to the vac line after the pcv valve while the engine is running (need someone to keep engine idle up so it doesn't die when you disconnect the line from the valve). It should be stocked at a local auto parts store. Here's a link: http://www.seafoamsales.com/motorTuneUp.htm
The directions are on the can.
What are the torque specs fot the plugs? Does the mark 8 engine have the problem of plugs loosening up like the late model cobras?
Thank you!!! I'll try it although everthing is running fine, I guess it can't hurt..............I hope.......lol
