TheLinkLS8
Does Ford have like a upgrade break setup like a Baer, or Brembo would?
TheLinkLS8 said:Does Ford have like a upgrade break setup like a Baer, or Brembo would?
Quik LS said:nope. the only complete brake kit is from StopTech -
Big Brake Kits
StopTech four wheel Big Brake Upgrade for the 2001 Lincoln LS. The kit includes ST-40 4-piston front calipers painted red, black, or silver, ST-40 4-piston rear calipers painted red, black, or silver, 7075-T6 billet aluminum caliper mounting brackets, 355x32mm slotted, floating, front AeroRotors, 328x28mm slotted, floating, rear AeroRotors, 7075-T6 billet aluminum AeroHats with directional standoffs, StopTech SS (DOT compliant) front and rear brake lines, Axxis Ultimate front brake pads, and Axxis Ultimate rear brake pads. Requires 18 inch or larger wheels, however not all 18 inch wheels will fit. Options: Drilled rotors - $100 per pair; Yellow or blue paint - $200 per pair of calipers and 30 day lead time.
$5195.00 - Item No. 83-530-4743
$2595.00 - Item No. 83-530-4700 - front wheel only
The StopTech Big Brake Kit will fit any year LS. Click below to see what the installation process is like:TheLinkLS8 said:i have an 04 LSV8, will any fit for mine?
TheLinkLS8 said:How are just some pair of bigger slotted rotors and brake pads?
Big Brake Kits
