QUICKSILVER_LS
can any one please show me how to program another Keyless entry remote for an 2001 LS V8...greatly appreciate
:L
:L
QUICKSILVER_LS said:can any one please show me how to program another Keyless entry remote for an 2001 LS V8...greatly appreciate
:L![]()
QUICKSILVER_LS said:Yes...i know.... but...my dealer charge 65$ just to program it....there must be some ways you can do it by yourself ....i program a Cougar by myself..i just don't how to do it w/lincoln...![]()
Currently the LS is the only Ford that cannot be done yourself.LS4me said:I saw again, ONLY the dealer has the ability to program your remotes. You can do the keys (as long as you have 2), but ONLY the dealer has the capability to program the remotes.
Quik LS said:Currently the LS is the only Ford that cannot be done yourself.
unlike most other Fords where you can switch the ignition from off-to-on 10 times and reprogram the wireless entry system - in the LS the dealer must use the Ford PCM programer and add them through the menu options.Jibit said:I don't have an LS but what's the secret behind the programming? What does the dealer use? Is it that the car doesn't have the ability to read and program a blank key?
right - you can purchase them all over the place - but you cannot add them to the car - only the dealer can. and you have to bring ALL your units - because you 'flush' the car's memory then add all the units.pragmatic said:Don't know if this would help but check out
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33723&item=7907415318&rd=1&ssPageName=WDVW
Jim Henderson said:I know the 2004 model you can do the reogramming yourself, I programmed one from eBay. The manual describes the procedure. I guess the non programmable remotes must be for earlier models, don't know what years tho.
Wish I could say the same about programming keys when you only have one.
Good Luck,
Jim Henderson
