Plug Wire removal..
Calabrio
Sarasota
I've worked on plenty of cars, many have DOHCs.
Yet, I've never had a harder time removing the plug wires than on my 93 Mark VIII. When I replaced them last summer, almost every single one of them broke.
I replaced the set, use liberal amounts of dielectric grease, and tonight when I went to go check my sparkplugs, I couldn't get the plugs to pull out. Stuck. Tight.
Anyone have any tips or experience with these plugs? Is it usually this difficult? Is there some unique tool that I need to use? I do not want to loose a $100 set of wires every time I want to change my spark plugs.
Twist/take em off every Oil change? Good question. If you put dielectric grease on them before I don't know how else you gonna keep them from sticking.
I'm just use to rippin' them off, taking out the plug and gettin' a new set. 33/year isn't that bad for some wires really...(assuming you buy 100 set of wires and the plugs/wires last you 3 years.)
I don't really have a solid answer how to take them off man, sorry...
It's just strange. are they ridiculously tight for everyone else?
The plug wires on my Mark are stuck on really good. I tried to pull one off last night and it just wouldn't come off so I sprayed some wd 40 on all the wires and will try again later.
What good will that do? Now they're going to be just as stuck, and slippery too.
Get a plug wire puller at a parts store.. It looks kind of like a set of tongs. Grab the wire boot and twist back & forth until it un-sticks, then the wire should pop right off.
I dunno about you but I've always had fairly good luck with stuck things being helped becomce unstuck with a little lubrication.
I don't want to have happean on my mark what happend on our 97 f150. I pulled the plugwire off and the wire and rubber boot came of but the socket wouldn't go on the plug So I shine some light down the hole and it i see a little metal thing smashed dow there. It was the contact on the end of the wire and it ripped off. I took me about an hour and a half to grind some pliers down to fit and then fish it out.
Also I technically didn't use wd 40, I used this stuff called aerokroil. It is an insanely good working pentrating lube. It is the best stuff I have ever used.
But how is spraying the wires going to un-stick the little metal thing up inside the boot? You can't get to it unless you remove the wire..
it actually does seem to feel like the rubber shafts are what are really causing all the resistance. As though the rubber expanded in the valve covers.
I just changed out plugs and wires on my 94, and the wires were date coded 1994. I'm not sure how old the plugs were, but shall we say they had a "rich patina". All my boots popped right off, and the plugs for the most part came out easily.
Maybe your car has cooties. :eek:
Yeah... http://www.lincolnvscadillac.com/showthread.php?t=26552
I noticed that too, it does seem like the rubber toward the plug-end of the boot is what's causing it.
I still have 4 left to do. I tried WD40 but only left it for an hour or so, when I try the other 4 I'll try lube again and let it soak in for several hours, maybe overnight. Otherwise it's back to my method of smashing the plastic boot with a screwdriver and hammer and vacuuming out the pieces, then fishing out the rubber end with a bent piece of a coat hangar..
On my car, both the old and new boots were difficult to insert / remove on some cylinders. Seems to be the plug tower seals on the cam covers that are the sticking point. I just put some dielectric grease on the ouside of them to help them slide in.
