Polished 70mm TB & EGR
Sifrino3
Prescott Valley, Arizona
It is a POWER throttle body and spacer. Perfect condition, I should be able to clean it up. Ran very little miles on it. It is polished. Like chrome. I paid close to $200. I can not remember correctly. It will come off as fast as I can get the nitrous hooked up. So, it may take a few days/week. But I know you will not get a better deal then here!
70mm Throttle Body
70mm EGR Spacer
~!Best Offer!~
Just as I move away from using NOS, more and more people are bringin' me back to it! I got the thirst for some now, post some times when you get back from the track Sifirino... ( sorry if I misspelled your name). :nos:
I will get to the track and you can bet on it that I will post up times with nitrous and without.
Sif, your heads don't flow enough for that 70mm TB. Don't put it on until you get better heads. You have to realize, the cross-sectional area of that TB is gigantic compared to the 61mm stock one:
A(stock) = 3.14159 * (61mm/2)^2 = 2922.4640975 sq mm
A(new) = 3.14159 * (70mm/2)^2 = 3848.44775 sq mm
That's almost a thousand square millimeters difference, Sif. You're going to kill your intake charge velocity and kill your low end torque. Yeah, nitrous will make up for it, but your car is going to suck on the street if you put this thing on without better flowing heads.
I already have it installed and works great. I have a surprise that I can not tell when I install the nitrous. Pictures will be posted! Im selling this polished 70mm tb and egr!
re-Markable LSC said:
I'll give you $75 if you end the auction.
$75 for a used but great looking TB and Egr Spacer? Are you kidding! Well, you could win the auction with a $50 bid. It doesn't look to good for me. . .
