02V8Sport
Though you guys would like me to share this.
Parts = approximately $55 most bought at Autozone
1- Spectre 3" Air Intake tube (come in different colors) $20
1- Spectre K&N look-alike cone filter $25 or use a K&N cone $40
1- Spectre MAF adapter (think its made for Hondas, sorry I said Honda
$5
4- 1/4 x 3x4 Bolts $.50
4- 1/4 Nuts $.50
4- 1/4 x 1 1/4 fender washers $.50
3- 3" hose clamps $1
1- 3" PVC coupler $2
1. Completely remove stock air box and unbolt MAF sensor. Throw airbox out, j/k.
2. Modify MAF adapter bought above to slot the holes larger so the adapter can bolt up to the cars MAF adapter. Use the 1/4 nuts,bolts and washers to attach them together. (I used a hack saw and cut the holes to the outward corners on the MAF adapter so there is room to adjust to make it fit properly with the cars MAF sensor)
3. Attach the 3 inch hose bought above to MAF adapter with hose clamp.
4. Shove the remaining hose through the hole, underneath where the air box was, to the bottom of the car.
5. From the bottom of the car attach the Cone filter, First shove the 3" coupler into the cone filter and clamp it leaving 1/2 of it hanging out so you can clamp on the intake hose. (I took out the 3 screws underneath that hold the splash guard on to fit the filter into the space in front of the drivers tire but behind the bumper)
6. Put splash guard back on and voila! Finished.
So now with the hood popped open, all you see is a hose with a slight 90 degree bend going from the MAF sensor to the bottom of the car where the airbox used to be.
This probably sounds like jumble, but I will snap pics sometime next week of the finished product.
This is the easiest way of making a CAI without too much work and money involved.
4- 1/4 Nuts $.50
