steagle
ok so check this out. took my car to EZ Lube last Friday for an oil change. the crew there was totally haphazard and unskilled i could tell, but hey it's just an oil change it's not rocket science. i figured they'd let me know if i had any major issues i needed to take care of; all they mentioned was the fuel filter was dirty and could go for a replacement (which is true) and one of my brake lamps was busted. turns out i need an all new assembly cause the bulb melted into the plastic and was impossible to remove. anyways, the important thing is that those were the only two things they told me about. i paid them and got on the road to Joshua Tree.
the next day i'm driving back to LA and my engine starts overheating. i pull into a gas station to check my fluids. the engine coolant resevoir is bone dry so i pay the bucks and get it up to speed. when i'm finally back on the road i start thinking about the oil change and wondering why i wasnt alerted to the low coolant level. i gave them a call yesterday to see if there's anything they can do for me considering that was a really big inconvenience and it should be standard procedure to make sure my levels are sound, at the VERY least just inform me i need to take care of that. the guy on the phone said he remembered me and he remembered my levels being fine, and that i could have a leak. that must have been one big ass leak then, if my coolant was at the right level, then down to absolutely nothing in under 24 hours.
but if the leak was that bad, how was my car driving perfectly fine before the oil change, then coincidentally after the oil change, the coolant is gone? anyways i'm headed over there after work to put it up on the lift and look underneath. i have a bad feeling about this, what would you guys do in this situation if both me and EZ Lube can't see eye to eye on this?
