Here's a internet compilation of The Mark
http://www.injectedengineering.com/MikeSchultz1998MarkVIII-43
http://www.vortechsuperchargers.com/page.php?id=663
http://www.bozeforged.com/lincoln1.html
http://templeperformancecars.com/customer-cars.html
http://www.youtube.com/user/themarksc/videos?view_as=public
http://www.streetfire.net/uploaded/themark.htm
https://www.sugarsync.com/pf/D1773116_034_681810095
https://www.sugarsync.com/pf/D1773116_034_681810024
Some of the Mods, Repairs, and Parts used on The Mark over the years...
M2300X Ford Racing/Brembo 13in 2000 Cobra R Front Brake Kit
136-2261002 Baer Eradispeed Extreme Plus 2 piece Front Brake Rotors for 1999-2004 Mustang Cobra
DP31031C EBC Brake Pads for 2000 Cobra R/Brembo Brakes
9904HABA Front Hub and Bearing Assembly for 1999-2004 Mustang Cobra
136-2262001 Baer Eradispeed Extreme Plus 2 piece Rear brake rotors for 1999-2004 Mustang Cobra
YR3Z1109AA Rear Hub for 1999-2004 Mustang Cobra IRS
E9DZ1215A Rear Wheel Bearing for 1999-2004 Mustang Cobra IRS
BR57B Rear brake pads for 1994-1998 Lincoln Mark VIII
Ed's Rear Caliper Relocation Kit
Classic Tube SS Brake Line Kit F&R
Custom Forged Boze Wheels Front wheel dimensions: 18x8 w/ 6.375 back spacing
Custom Forged Boze Wheels Rear wheel dimensions: 18x9 w/ 7.500 back spacing F&R Wheel Spacers - 1/2"
Front – 235/45/18 Pirelli PZero Nero
Rear - 265/40/18 Mickey Thompson ET Street Drag Radial
Vortech Supercharger Tuner Kit
Vortech V-2 T Trim Supercharger Compressor Polished with Heavy Duty Bearings
Vortech Idler Pulley – Upgraded Newest no squeak version
Polished Treadstone Intercooler TR10 24in Long core
Custom Polished Aluminum Intercooler Tubing - 3 1/2" intake, 3" discharge
Siemens Deka 60lbs injectors
Ford GT supercar fuel pump
ATI 10% overdrive 8 rib balancer damper
Kenne Bell Boost-a-pump (2 - had to replace the first one in 2013)
NGK BR7EF Spark Plugs
Ford Racing Aluminum Radiator 03/04 Cobra
97-03 Mustang/Cobra Electric Fan
Mustang GT MAF for 2005 Mustang GT
MAF Plug for 2005 Mustang GT
VMP MAF adapter for 2005 mass air flow sensor into aluminum tubing MafXtender
Kooks 3/4 Headers
Magnaflow polished SS mufflers
Magnaflow high flow cats
SCT Xcal2 Flash tool
2 1/2" Custom mandrel bend SS exhaust
PI multi disc 3600 stall torque converter
Dynotech Metal Matrix Drive shaft
Ford Racing 410 gears
Ford Racing Trak-Lok Diff
Raxle SC T-Bird rear half shafts
ARP Racing Front and Rear Extended Wheel Studs
SCP Pinion Brace
Poly Diff Bushings
SCP Rear Cover Brace
Bradshaw Bros. Custom built 500 rwhp racing 4r70w transmission
Ford Racing deep well trans fluid pan
Custom built Ford plate style trans cooler w/SS braided lines
Pioneer in-dash navigation system and multi-media head unit
Myron-Davis DVD player
Polished 96-98 Cobra Intake
Two Vortech Maxflow Racing bypass blow off valves
Polished ACCUFAB Single blade throttle body
Injected 302 Stroker Kit
Custom Manley Pistons-off set
Manley H-Beam Rods
ARP 2000 Bolts
Total Seal Stainless File Rings
Federal Mogul H Rod & Main Bearings
ARP Main Stud Kit
ARP High Tensile Strength Head Studs (with 12 pt nuts)
Melling High Volume Oil Pump with Billet Gears
Refresh Cylinder Heads
MET-MBR0004 - Screw in type valve cover breather modified and welded bung to accept -10 Earls 120 deg hose end
Aerospace Crankcase Evacuation Tank
Earls -12 Pro-Lite black hose and misc -10 & -12 black fittings
FOMOCO-XR3Z6B209DB - Steel tensioner recall kit for 96-98 Mustang Cobra
OEM-MC-PW470 - Water pump for 96-98 Cobra
FOMOCO-F3LY6K297A - Timing chain guides
FOMOCO-1R3Z6M256AA - Timing chain guides
FOMOCO-1R3Z6L253AA - Timing chain guides
FOMOCO-1R3Z6L253BA - Timing chain guides
FOMOCO-F7LZ6K254AA - Timing chain tensioner for 4.6 4v B Head
FOMOCO-F7LZ6K254BA - Timing chain tensioner for 4.6 4v B Head
FOMOCO-YR3Z14300BA - Mustang Cobra/GT Pos and Neg Battery cables
Enlarged 2 ½” SS Pipe Modified Stock Mark VIII Exhaust Tips.
Pioneer Ipod Adapter
Strut Bar Bushings
Ford Outer Tie rod Ends
Ford Upper Control Arms
Wheel Alignment
American Air Suspension 1 ½” Lowered Coil Spring Conversion
1998 Mark VIII Collector Edition Wood Shifter
Bend Door Actuator Motor (Replaced twice - 1 in 2002 & 1 in 2011)
Ford Mark VIII Custom Fitted Car Cover
97-98 Mark VIII Steering Column
Lower Radiator Hose 2003 Mustang Cobra
Assorted T-Bolt Clamps
Assorted Silicone Couplers
S&B Cone Air Filter 4” Inlet
Sway Bar End Links
Hub Dust Caps 2004 Mustang
Throttle Cable 1999-2001 Mustang Cobra
Throttle Cable Bracket 96-98 Mustang Cobra
Complete Ford Engine Gasket Kit
8 Bolt Flexplate 2004 Mach 1
IMRC Controller 96-98 Mustang Cobra
1998 Mark VIII Alternator
Billet Modular Crank Trigger
PMAS HPX Slot Style MAF
TPS Sensor
Ford o2 Sensors and long lead 4-wire for headers
Percy Header Gaskets
Temple Performance Terminator Front Bumper Cover
Terminator Cobra Fog Lamps
Temple Performance Rear window trim repair kit
Reische Performance FORD-4D 170deg Performance Thermostat
